My 94Z w/lt1 6 speed (all stock) bucks and sputters at low rpms in first geer. I had the distributer replaced once at about 60K or so and that solved the problem for a long time....now with 133,00 k, the problem has started up again. Also, any advice on a now wobly front suspension and steering that seems to take a little bit too much effort to turn the wheel? Might I also add that the reverse synchro is shot. Other than selling it ( I am original owner) any advice? Joe
94 LT1 Z kicks and bucks....
94pologreenzTags: None
"My 94Z w/lt1 6 speed (all stock) bucks and sputters at low rpms in first geer. I had the distributer replaced once at about 60K or so and that solved the problem for a long time....now with 133,00 k, the problem has started up again."
Sounds like it's time for a new OPTI.
"Also, any advice on a now wobly front suspension and steering that seems to take a little bit too much effort to turn the wheel?"
Check the rag joint. This is the thing that looks kind of like a U joint on the steering shaft under the hood.
"Might I also add that the reverse synchro is shot."
Reverse doesn't have a synchro. As transmissions get older, the bearings get a little stiffer. Try putting it in first then reverse. This will stop the idler shaft from spinning and allow it to go into reverse without grinding. Just make it a habbit.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
not to throw a fly in the ointment...
Gear Ratios:
First 2.97:1, Second 2.07:1, Third 1.43:1, Forth 1.00:1, Fifth 0.80:1, Sixth 0.62:1, Reverse 3.28:1
Design Torque Rating: 400 lb-ft
Approx. Dry Weight: 125 lbs.
Key Features:
*Single-rail internal shift system
*Synchronized reverse gear
*Needle bearings for all mainshaft gears
*Heavy-duty rapered roller bearings
*Powered-steer synchronizer blocker rings with organic friction material1998 TA M6 SLP Lid, Cold Air and Bellow, Flowmaster 3", Centerforce DF, Fast Toys MAF ends, JET skip shift eliminator 312rwhp/366rwtq
92 Lincoln Mark VII LSC For Sale
Visit Central Jersey Mustangs & Fords
That's news to me. But if you put it in first then reverse it won't grind.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
that was from a GM website that had tech data on the T56...
The T5 also had a synchroed reverse after 91 or 92...maybe it was 93, but I know it was one of those....
Yeah, do the forward reverse thing and it won't grind
