Anyone with the M6 have this prob? Above 85 (on the track
), when I let off the gas, the center console starts vibrating.. If I stay on the gas, it doesn't. If I push the clutch in at those speeds, same thing, or if I throw it in neutral..
Any ideas? Driveshaft outta whack? Not sure why it wouldn't vibrate under load though, and only when coasting..
Also, if I remember correctly, my 94 Formula A4 did the same thing..
Thanks for any help.
), when I let off the gas, the center console starts vibrating.. If I stay on the gas, it doesn't. If I push the clutch in at those speeds, same thing, or if I throw it in neutral.. Any ideas? Driveshaft outta whack? Not sure why it wouldn't vibrate under load though, and only when coasting..
Now, I am stuck with a tranny overhaul. Since I need to pull it, I am doing synchros as well
