Where is the access to the rear shocks mounting from inside the trunk space, ive spent 30 minutes playing with the rear palstic cargo moldings just to take them off and put them back on.. the desing sucks back there..any inout will be greatly appreciated.
Shock Replacement
You have to lift up the carpet in the trunk area, after you remove the plastic shells on both sides.
Then remove the big pieces of foam and the nuts are under there.
Randy99 TA "RBLUTA" - NBM, M6, Whisper Lid, SLP Fan Switch, 160* Thermo, SLP LM, BMR STB & LCA's.
Fold down the rear seatback. Pull the carpet on the package shelf up at the seam right behind where the top of the seat was. There will be an irregularly shaped dimple in the corner of the package shelf, with a foam "falsie" in it. Pop the foam out, as noted in the post above.Fred
