i am going to get a pair of 16 in rims for dr's, i was wondering what the size of the tires are.
tire size for 16 in rim
Adam 2kSS #4959 6-speed
PERFORMANCE: whisper lid, mac headers w/ offroad y pipe, SLP Loudmouth, LS1 hotcam, ls6 springs, Predator, ngk tr6's, spec stage 3 x-pad, steel billet flywheel, 5177, purge, bottle heater, moser 12 bolt, 4.30 gears, tb coolant bypass, FRA, !cags, !egr, !A.I.R.
SUSPENSION : eibach pro kit, bmr boxed lca & relocation brackets
APPERENCE : clear corners, camaro fill in on front bumper and back, black and silver SS badges
http://www.geocities.com/xxlo00oixxTags: None
is that size close in diamater, to 275 40 17?Adam 2kSS #4959 6-speed
yes it is. the thing to remember about tire size...proper tire size..is rim width! that determins what aspect ratio section width to run. the design rim width for the 245/50r16 is 7.5 and 8.0 for the 255.Originally posted by Adam 2kSS
would there be much of a traction loss from 275 to 255'sAdam 2kSS #4959 6-speed
Why not stay with the 17" rims.... you could argue that the lower sidewall hurts you, but you will be closer to stock, won't be like using 3.37 gears in place of your 3.42's, and you will have a little extra tread width.....
BFG Drag Radials:
275/40-17
-rim 9-11"
-tread 10.2"
-section 11.0"
-diameter 25.7" = stock
255/50-16
-rim 7-9"
-tread 9.7"
-section 10.3"
-diameter 26.1" (0.4" larger than stock)
If you are buying wheels, get some 15" wheels that will fit in the back with minimum alterations to the brake calipers. Then use these, with a big, flexy sidewall:
275/50-15
-rim 7.5-9.5"
-tread 10.0"
-section 11.3"
-diameter 26.1"Fred
