do i need headers to see a gain from a bigger cam and rockers?
  • do i need headers to see a gain from a bigger cam and rockers?
    if i just have a different muffler and mayb a cat-back if money permits will i see a increase in power with a larger cam or will the extra exhuast i have from the valves opeing more get bottlenecked on the way out?
    1994 firebird formula
    You don't NEED headers, but you will definitely benefit having them. I believe you could also have your stock manifolds ported and then put a good y-pipe for better flow. However, I would just suggest a good set of headers, especially when you are starting to get into the internal motor. Remember, a better cam and rockers means more in and out, so the best suppliment is the headers for a tuned exhaust (especially considering that you already have a good cat-back).
    Just my $0.02.
      This is how I would put it:
      Why would you build an engine that CAN pump more volume of air, but not let it actually flow that volume of air?
      Just something to chew on
      KnightFire
      1993 Formula Firebird
      KnightFire's Lair
      Amsoil Dealer
        I was going to say the same thing.
