The engine stopped as I was
for the green light at a crossing(it was at idle).
I tryed 7-8 times to start and it finally started. Then I drove for a while, but when I pushed the accelerator all the way, the engine almost stopped running and I could see the headlights flickering. When I accelerated slowly the engine revved up ok.I turned off the engine. I couldnt get it started since(8 months ago).
I checked the spark -seems ok, i put a test light on the injectors connectors- seemed ok too. Checked the fuel pressure, but without a gage- pressing the schrader valve a little fuel came out, 10 cm up.
Trying to start the car, some mechanics broke the fuel pump, and the starter motor runs slowly and noisy.
What do you think the original problem was? A weak fuel pump or other problem(opti)?
I live in europe and i cant find a mechanic who can fix mmy pontiac without breaking something else, so I have to do it myself. HELP
correct your all caps subject line for ya.
for the green light at a crossing(it was at idle).I tryed 7-8 times to start and it finally started. Then I drove for a while, but when I pushed the accelerator all the way, the engine almost stopped running and I could see the headlights flickering. When I accelerated slowly the engine revved up ok.I turned off the engine. I couldnt get it started since(8 months ago).
, but after the battery was disconnected
But seriously, is my reasoning off base in this situation?
