Man, like a noob here...hate to ask a dumb question but, is the picture correct? I'm trying to locate the area of where it's leaking pressure. I tried using vice grips to clamp off the supply line once it's pressurized. I also tried the return line once it's pressurized in order to see where it's leaking. (The supply line is slightly bigger than the return line in case you can't see the pic well). It didn't seem to matter where I clamped it off...still kept losing pressure.
In fact, I tried clamping off the supply line (or what I think to be the supply line) before I even pressurized the system, yet it still keeps initially pressurizing to 44 psi.
By the way, I tried 3 clamps and am 99% sure I cut off the whole line.
If I'm wrong, where would I clamp it off in order cut off the supply/return line?
Thanks in advance.
