Anybody Know what fuel pressure LT1's are supposed to run? My 95's been acting strange like she's lean and when I checked the fuel press. it was around 20psi. Seems way too low to me, I thought SFI motors ran a lot higher. Have any of you guys experienced low pressure? I'm thinking regulator issues as the filter was just changed 15,000 mi ago.
Fuel Pressure
Could just be a weak pump. 20psi is way too low. As noted in the post above.... 41 to 47psi with the vacuum line off is the factory spec. Reattach the vacuum line and the fuel pressure will drop proportional to manifold vacuum... a 6 to 8psi drop is normal. The pump should hold within 1 or 2psi of the "no vacuum" value at WOT, all the way to redline.
You can check the fuel pressure regulator by looking at the vacuum line. If the regulator diaphragm is bad, fuel will get into the vacuum line.Fred
