I've been talking to a guy in Washington state about a race car he has for sale. It is a 1997 Camaro Z-28. The car has no motor or tranny, but as some of you know I am putting together a solid roller LT4 right now.
He is asking $7500 as it sits. He has $4000 just in the 9" rear end! He is supposed to be e-mailing me some pics tonight so as soon as he does I will post them.
What do you think, is this worth the drive drom SA,TX? I am considering selling my stripped 97 WS6 as a project car for this car. Let me know your thoughts.
Here is a brief list of the car's mods:
97 Camaro Z28 Stock Style Suspension Racecar
NMCA Drag Radial or EFI Legal
PSCA Limited Street, True Street, or Wild Street Legal
PRO/NSCA Xtreme Street Legal
LS1Tech Racing Series Legal
Chassis has 24k miles
Chassis:
-Brad Hadman Progressive Metal Craft Chromoly Rollcage Cert. to 7.50 till 2-06
-PA Chromoly K-Member, and A-Arms
-Pinto Style Steering Rack w/ adjustable Bump Steer Ends
-Glasstek Dzus Fastened 4" Cowl Hood Painted
-Ed Quay Sheetmetal Pro Strut Wing
-Cowl is cut and molded to Firewall
-All Engine Bay Holes filled, Bay Painted Gloss White like Rest of Car
-Heater/AC hole in firewall Covered/Welded/Painted to be one Piece w/ Firewall
-(New)2 Sparco Racing Seats, with Sliding brackets
-Removeable Parachute Mount, w/ Stroud Parachute
-(New)Aerospace Drag Brakes on All 4 Corners
-Converted to Manual Brakes w/ Wilwood Master Cylinder
-Solid Tubular Chromoly Motor Mounts for LT1/SBC/BBC
-Suspension:
-Wolfe Racecraft Chromoly Torque Arm
-Wolfe Racecraft Solid Anti-Roll Bar
-Custom 76" Pro Stock Type Wheelie Bars (Powdercoated Black)
-CUSTOM easy adjustment Spohn Moly Rod End Control Arms
-Chromoly Rod End Adjustable Panhard Rod
-QA1 Coilover Front Shock/Spring Package
-QA1 Rear Shocks
-OEM Z28 Convertible Rear Springs
Rearend:
-Narrowed 9" Rear
-(New)Moser Gundrilled and Flange Lightened 35 Spline Axles
-(New)Strange UltraCase Centesection w/10 Bolt Pinion Support
-(New)Aluminum 35 Spline Spool
Tires/Wheels:
-(New)Weld Alumastar One Piece 15x3.5" Front Wheels
-(New)Weld Alumastar 2 Piece 15x10" 4.5" BS Rear Wheels
Electrical:
-Painless Wiring Streetcar/DragRace Wiring Harness
-Autometer 2 5/8" UltraLite Aluminum Guages (Oil Press, Fuel Press., Water Temp, and Volt)
-Guages Mounted in Factory Location in Custom Carbon fiber Panel, Behind factory glass)
-Rear Mounted and Sealed Battery w/ Shutoff Switch
Fuel System:
-(New)Charged Air Systems Fabricated Fuel Tank
-Magnaflow EFI 600 Fuel Pump
-Aeromotive Filters Before and After Fuel Pump
-Product Engineering Y-Block
-12Sump Line, -10 Main Line, -8 Return Line
-All Earls and Aeroquip Fittings
Chassis:
-Suspension:
-QA1 Rear Shocks
Rearend:
-Narrowed 9" Rear
Tires/Wheels:
Electrical:
Fuel System:
, but I've heard rumor it is in the 280 dur range @ .050 on intake, and over .720 intake lift.
