Nitrous Questions
  • Nitrous Questions
    Couple Nitrous Questions.
    #1 What is the difference between Wet vs Dry Nitrous?
    #2 Is it appropriate to use when street racing?
    #3 What should someone do to prepare their 4th Gen F-Body prior to installing nitrous? Anything to prevent damaging the vehicle.
    #4 How much more horses can one gain with Nitrous?
    Thanx in advance guys.
    Mixedpuppy
    1998 TA, mostly stock, SLP hood, ram air plastic intake, K&N Filter, Transgo Shift Kit, Kooks Stainless LT headers with Magna Flow Cats, Borla Exhaust (Medium plate setting), Kenny Brown SFCs, BMR Tower Strut Brace, 17" ROH RT Rims, 9.5 BFG KDWs, SLP Airlid, Smooth bore bellow, 85mm MAF. Nitrous to come. Action figure not included.
    Re: Nitrous Questions
    A wet kit injects nitrous and gas into the manifold, a dry kit injects nitrous only. Additional fuel comes from the injectors.
    Street racing is way too dangerous, besides being illegal. Nitrous is used when you want to gain that extra power.
    Have a really good fuel and ignition system
    The most that should be injected in a stock motor is half of it's original HP. example..... a 300 HP motor should only be asked to withstand another 150HP from nitrous for a total of 450.
      Here's a link that will explain the basics.
      Dry nitrous adds ONLY the nitrous to the intake manifold, and uses the stock fuel injectors to add the extra fuel. Wet nitrous adds the fuel and the nitrous to the intake manifold.
      It can be used, but its hard to control. Nitrous tends to be "on" or "off".... no in between. Add a sudden 150ft-lb of torque and you better have some good tires under the car. There are ways to control is... progressive controllers or staged systems that bring the nitrous on slowy to prevent blowing the tires away. Or you just spray in 2nd gear.
      Follow the link. For a wet system, you will need to find a way to get the fuel to the spray nozzles or spray bar. For a dry system, stock injectors can't handle the elevated pressures so you might need to replace them. In general, the stock platinum tipped plugs are a poor choice for nitrous. And you will generally need a slightly colder plug, and a smaller gap. For anything over 100HP, its a good idea to retard the ignition timing a few degrees. There are ignition "boxes" available that will provide this and improve the spark.
      Those boxes will also incorporate a "window switch". This allows you to set the lower RPM limit for the nitrous to activate (you don't want to spray below 2,500-3,000rpm) and the upper limit for a rev limiter (you want to cut nitrous before the stock "cuts fuel" limiter kicks in). It doesn't hurt to add a fuel pressure safety switch (cuts nitrous off if fuel pressure drops), and things like fuel and nitrous pressure gauges.
      #4 How much more horses can one gain with Nitrou under the car. There are ways to control is... progressive controllers or staged systems that bring the nitrous on slowy to prevent blowing the tires away. Or you just spray in 2nd gear.
      For a stock engine, I'd say limit it to 150HP. There are people running up to 200 on a stock bottom end, but I wouldn't. The kits in the 125-150HP range are best. With a built up bottom end, and good tuning, 300HP is possible, and probably a lot more if you are building an all out track motor.
        THANKS INJUNEER,
        Your a real asset to this site. Appreciate the experience and insite.
        Mixedpuppy
