52mm TB on stock car
  • 52mm TB on stock car
    Does anyone have any "proof" showing a 52mm TB on a stock car can hurt performance?
    Just out of curiosity, do you mean stock as in a stock motor with bolt-ons, or bone stock everything?
      Stock everything. I've heard in the past a bone stock car will actually lose a little power with a 52mm TB. I'm looking for proof.
        I've heard that too...but I too have no proof...just someone's word on it. I could have sworn I heard Ken say that someone lost 4 hp, but I'm not sure if it was a switch from an bolt-on LT1 to a 58 mm TB, or a bone stock LT1 to a 52 mm TB.
          There was an actuall Dyno run which proved that converting to a larger TB will cause you to lose HP. It was posted here a while back, but I dont remember the exact details on the car. I think Injuneer posted it, but Im not sure. Maybe he can remember. The car had a few mods already if I remember correctly, but nothing beyond minor bolt on's.
            The only actual dyno test I saw was for a 58mm throttle body on a relatively stock LT1. It lost 10HP, but it was a little bit subject to how you interpreted the dyno curves.... I wouldn't have interpreted it quite that way, but it definitely "lost" power, maybe only 3-5HP.
            A also have a set of dyno sheets from a website that no longer exists, and they tested a bunch of popular boltons, on a mildly modified (300rwHP/320 lb-ft reTorque) 96 Z28. Some of the results:
            52mm TB: +2.5HP, +3.2 lb-ft
            Remove MAF screen: +1.1HP, -0.4 lb-ft
            TB airfoil: +1.1HP, -1.90 lb-ft
            MSD 6A/Accel Supercoil: +3.5HP, +4.7 lb-ft
            HPP+: +3.0HP, +0.9 lb-ft
            Most of those gains/losses are so small that they may just be the "normal" variances you are going to get from one pull to the next.
              I drove a basically stock LT1 with a 52mm and I didn't like the throttle resonse. The car felt really jumpy, not smooth in the power delivery and there was no gain in WOT performance. It was the part throttle performance that was really annoying. Much less linear, hard to give smooth throttle input, etc.
