Hey Eveyone,
I got a problem. My tranny is acting like a manual valve body and I don't know why. It used to do it every now and then, I'd just shut off the car and start it back up and it'd be fine. Now it is doing it all the time. If I put it in drive, that is what gears it starts in, 3rd is 3rd, and if I put it in 2nd it starts off in second gear. My shifter doesn't have a first, but you can pull the shifter back far enough to get first. When I try to put it in first it still starts in 2nd gear. The tranny was rebuilt September '02 w/ kevlar bands and about Febuary '03 it was parked and didn't move until about September '03 when I got the car. and it was fine untill now. Anyone know what could be the cause of this??????
Thanks,
Thanks,
Could also be a bad low sprag. In any case, it's rebuild time. Since it has to be opened up, when it is rebuilt, make sure that a few parts are upgraded. You want a hardened sun shell, a higher number element low sprag, corvette servo should help in the longevity dept. The low sprag and sun shell are common failure parts. The servo just helps with fluid control.
