I'm getting a DTC code PO300 misfire condition. I just replaced the wires, plugs, added headers and a new y-pipe with o2 sims. A real slight change in rpm can be heard; the SES light actually flashes when revving at a constant 3k then stops flashing when the rpm's are back at idle. I made sure when I attached the wires to the plugs, opti and coil that I heard them "snap" on. Maybe I should have checked the resistance of each wire before installing them. Iheard that Taylor's were pretty good wires.
I turned off all the lights in the garage and didn't see any sparking anywhere under the hood, from above or below. Just for the heck of it I checlked the resistance across the #7 spark plug (NGK TR55) and it was around 5k; I checked 2 of the original AC's and they were 2k.
Any opinions on what I should look for or do next??
We really cant tell you much from that - you almost have to have the car in front of you with the scanner. If I had a particular symptom and a freeze frame on the scanner at the right instant, that would be a different story.
