Filter !!!
  • Filter !!!
    hey guys;
    I have a 95 camaro 3.4L. Does anyone know where the canister is on this thing so i can check the filter ?. Also has anyone experienced a clogged canister filter and if so,what was the effects it was causing to your car ?
    Thanks, ron
    Black on black 1995 base t-top camaro with a 3.4L
    My 3rd gen V-6 would run rough at times, especially if I really got on the throttle it would almost die. Changing the fuel filter cleared these problems up. As for the location of the fuel filter on your ride, I am not sure.
    98 Arrest Me Red Z28 - A4 with 2 washers and B&M SuperCooler, SLP CAI and airbox lid, K&N filter, smooth bellows, WS6 polished wheels (17" x 9"), Power Slot front rotors
      Drivers' side rear under the car. It is in front of the left rear wheel underneath the car in line with the 3 fuel lines you will see. Can't miss it.
        carbon canister filter
        thanks guys, but i really meant to ask about the carbon canister filter. but thanks anyways
          Chiltons does not show a separate "filter".... on the V8, the evap emissions charcoal canister is in the driver's rear fender, behind the fill pipe. It is accessed by a plastic panel in the wheel well. I would suspect that the V6 and V8 canister setup is similar. Appears that the canister may incorporate a filter, but I was under the impression that the canister is a "sealed" unit.... could be wrong, because I have never looked at mine.
          Diagram courtesy of SHOEBOX
