Does anyone know if the Corvette gear reduction starter made by Nippendenso (p#1045579) will work on the F-body Lt1? Seems like the hot setup if it works.
Starter application question
Tags: None
Don't know about that one. I have a CVR ProTorque starter that is gear reduction, and can be rotated to clear headers. About $150 from JEG's, but I don't think they show them in the catalog any more.
Hmmm.... 180 bucks for a stock starter, or 150 for a high performance gear reduction starter??? Yea.........
Actually, I may have mine rebuilt. Im still deciding. Thanks though.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
There is also an "LT4" starter that costs about $150 from the discount GM parts sources.Fred
I have no money left after my rearend/ rear suspension project so, I bought a used one. With my luck, i'll be replacing it again in a month or so
What makes it an "LT4" starter? Do you know whats different?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
