do u think it could happen?
  • do u think it could happen?
    a 94 firebird formula 80,000 k very well kept, brand new tune up
    slp cold air intake
    trickflow intake elbow
    air foil air foil
    cat cut out
    tb bypass
    flowmaster muffler
    373 gears
    run a 13.5?
    if not,wut can i do to hit this
    i no i want to get mac long tube headers and ofroad y-pipe
    slp loudmouth
    but moneys tight,im only 16
    any repsponses taked seriously thanks guys
    1994 firebird formula
    You would have a half a chance if you could get traction. I bet traction would be your problem. Do you have a plan to deal with that? Cause the strip can feel a lot greasier with stock street tires than the street. You might just sit there & spin.
      Probably,add cool night air and it is practically sure thing!!!!!
        the flowmaster muffler is nothing but a sound chamber..that wont help anything..unless you get the rest of exaust system flowing free....but you said a cut out..so why bother spending money on the muffler? the air foil does nothing untill you are moving tons of air through the TB...like with a super charger or turbos.....and then..most likely..you would have an aftermarket tb that got rid of the problem. dont waste your money on the air foil. you didnt mention this..but get "cool" man...you need to a get a 160 thermo stat and program those fans to kick on aat 175 degrees to run better.
        and..traction...thats the key...as spoken already.
          But the intake,elbow,gears should do it on a good night,the other things are fluff,I agree!!
            I dunno...with the minimal mods you have that might be a tall order.
            It would all depend on the 60'...I would at a MINIMUM get some headers and full 3" cat-back exhuast to help with the breathing. You mention 3.73:1 gears so I'm guessing you have an A4, I would seriously look into a Vigilante 2800 converter or the like...Then I think you would own the mid 13's with a decent tire and short time.
            KnightFire
            1993 Formula Firebird
            KnightFire's Lair
            Amsoil Dealer
              Try and see sounds fun
              1997 Trans AM WS6 vert
              1 of 463
              LT4 knock module
              strut tower brace
              SLP fan switch
              160* t/stat
              Pictures Here
                I ran that before the 3.73s so I think that is indeed possible. Especially with the cut out.
                  the cut out is just a 3 inch pipe,in place of the cat
                    I kinda doubt you'll get those numbers with those mods unless you get awesome traction. I have similar mods CAI, Airfoil (was on there when I got it) 3:42 gears, and Cutout and have been running about a 14 flat . My main problem is traction off the line. My 60' times are running around 2.1xx-2.2xx on a good launch with little spin. Some Drag Radials (or 315s ) or maybe LCA and Relocation brackets and I should be well into the 13s. I would do the traction mods before you go with more power and you should be close to a 13.5. Also a good shift kit might be good for a few tenths. Good luck.........Later
                      and about the whole exhaust, i dont really have that much cash to play with till summer, i still have the receipt for the muffler my dad bought it for x mas present, it was 89 bucks, so i dont know,i need a new muffler soon, and unless i can find headers or a cat-back for about 250, i dont think i do them this soon.
                        so the b&m shiftplus kit, it is cheap, but i was told that it does little more than the performance kit i have, and how much and wut type of traction things could i get, cheap, i have my stock wheels in the basement, could i mount some good tires to those?
                          That would be a test pipe not a cut out. A cut out dumps the exhaust in front of the muffler or cat.
                            i said the cat cut out-meanin i have the cat cut out sry
                              LCAs and LCA relocation brackets will run about $200 for both. http://www.bmrfabrication.com/F-body...tm#controlarms You could put some drag radials on your stock rims for $266 new from tirerack.com http://www.tirerack.com/tires/tires....omCompare1=yes
                              or try and get a used set from ebay or something, good luck.....Later
