need help please car runs bad
  • need help please car runs bad
    hi
    im going to tell you whats wrong and a list of parts ive had replaced
    the car is a 2.8 mpfi 85 camaro berlinetta 4speed auto with od and 98,000 kilometers
    it has a hesitation problem only sometimes, and when it hesitates the worse i feel the backfire in the intake.
    it used to chip the tires when i wanted to get it moving
    im getting bad milage, i think it is running rich as it killed my o2 sensor and made my manifolds turn blue and leak
    i get 300 kilometers to a full 55 litre tank (about 185 miles?) of highway, a month ago i was getting solid 450 kilometers per tank and i dont keep to the slow lane much.
    the car feels less powerful and it downshifts constantly to try and keep speed. when i accellerate it feels like it doesnt have much power until it gets above 4000rpm
    when i drive on flat roads i can feel a slight surge like someone is rocking my seat slightly
    those are all the symptoms i can think of trhat started a month ago that it didnt used to do. i drove it all winter.
    when i got the car last summer 25,000 kms ago i replaced
    plugs wire cap rotor
    pcv valve
    air filter
    recently in the past few weeks ive had replaced
    coil
    starter solonied
    air filter
    tranny fluid
    fuel filter
    plugs
    cleaned iac
    i had the cat cut off to see if it was plugged and it is not.
    cleaned engine temp sensor connection
    run lots of fuel injection cleaner
    i always get the oil changed on time with 5w30
    hope i can get some help as its a bugger having my car break every long weekend it seems. i have the next few days off and weas planning to go on a 4000km road trip to visit parents but am not as the car isnt working well.
    hmmm...
    well you could check your timing. I had some of the same problems before when my timing was all screwed
    88 z28 Cam 305 V8 TBI
    79 z28 Cam 350 (still in the works)
    88 i-roc Z28 Cam 350 Tpi
    Keith
      YES! problem solved
      my distributor cap was coming out and set the timing off 20*
      im going to pick the car up now
        Originally posted by kevin 2.8
        YES! problem solved
        good news!!! Don't ya love it when its an easy (and cheap) fix!!
        95 Z28, A4, 3.23's and some other stuff....
          oh helll yeah
          the guy who fixed it works 7 days a week even holidays,
          and hes doing my 86 lincoln towncar so i dont have to drive the camaro for winter as well
          this time that traffic pole is going down! muhuhwahaha
