Ok, after my recent rear end whine, I've decided to take it to a local shop and get them to do my gear upgrade. What brand should I use? I've been looking at the Motives. I can take a LITTLE noise, but my main concern is durability. What ratio is recommended, the 3.73, or 4.10? I've heard that the 4.10 gears take some top speed off, is this true, and if so how much from the 3.42? When changing the ratio what all other services should I make sure the shop does (like maybe calibrate the spedo)? I've done a lot of mechanical work, but I've never messed around with the rear, so any input is appreciated.
Thanks,
Aaron
Thanks,
Aaron
. I'm
to hear if it is a problem with the gears or the backlash making the noise. If the gears are fine, I'm probably just going to leave them in. If the gears are shot, then I get to put the 4.10s in. Isn't it ironic how I can wish that something is wrong with them?
Ok, everyone pray for messed up gears, and I'll keep you posted.
have ever had a crack in the dash.
) so by all means go with the 4.10s
