Hey everybody, I just notice my car when turning left it makes this noise which sounds like when your brake pads needs to be changed. Also the sound appears sometimes when I am just driving normally. The noise is more noticeable and is a little bit louder when turning left. But when turning right no noise. I was wondering if anybody would be able to give me any suggestions or ideas on what I should check. Thanks in advance for your help.
Car Making Noise When Turning Left
Eric Lelina
95 Z28
Tuned by Carolina Auto Masters
302hp and 335tq
M6,GMPP CAI,1.6 Crane Gold RRs, MAC Headers,1LE intake elbow,Air Foil,!TB Bypass,Hypertech 160 Thermostat,Taylor Spiro-Pro 8mm Wires,Accel Super Coil,MSD 6al,SLP 2otl catback, Eibach Pro Kit,DMS SFCs,Hotchkis STB,BMR Adjustable PHR,Global West LCA,1LE Sway bars front and rear,KYB Gas-A-Just shocks, Energy Suspension Tranny Mount and Endlinks,Prothane Poly Torque Arm Mount,LS1 Driveshaft,17x9 SS rims.Tags: None
Check your C-Clip in the diff,one fell off on my 10 bolt and I was wondering why everytime I would turn onto the return road it would sound like hell[like brake pad warning] but only to the left.
Opened diff and C Clip had fallen off and the shaft was free,thank goodness the disk brakes held it in,as opposed to what mustangs do,the axle just slides out!!!!94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
Thanks for the help, I forgot to mention that the noise is coming from the front driver side tire.Eric Lelina
95 Z28
302hp and 335tq
Thern disregard what I said then!!!94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
I have just 5,000 miles on these brakes and thyere making the same noise as yours are when im not even on the brakes. except its both left and right.94 Firebird Formula LE3 383 - Built 4L60E w/ 3500rpm stall - Macs into SLP LM - 3.73s in stock rear - having fun with problems
