I just noticed my lt1 leaking from what looks like the rear main seal is this a common place for a leak?! also how hard is it to fix this leak and other common leaks?
Common Oil leaks
Intake oil leak
Go to Ken's fix...the best way to fix it correctly...the only way to fix it correctly
http://www.geocities.com/MotorCity/Downs/4013/ol.html94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
how hard is this leak to fix myself?! How much if i had a shop do it..... also how long before it becomes really bad for my motor?1995 T/A (jet black) flowmasters, and a K&N with homemade ram air, descreened M.A.F. and T.B. by pass.......
other parts........ and $$$$$
E.T. on a full tank of gas, 15.1 @ 94.21, A4, 3.23 gearing (bone stock pass.)
its time consuming. gm pays 2.6 man hrs for it. but you have to be real careful to connect everthing back up right. and it helps to lay the intake on with two people...that way you can drop it straight down.Originally posted by xxemoxx
whats really bad..is all that oil thats running down all over everything under there. and you have a vacuum leak now..and its going to get worse. a shop will do it for under 300.00 bucks.. but if i were you ..id scout around...some of the smaller places with experienced dudes will do it for 175.00 or there abouts.
alas, mechincal skills i have, a shop and space i do not. Sadly i live in a apartment how ****** is that?! Well i am going to scout around for those cheaper shops i just sold my rims from a old car so i am going to blow it on this one to make sure everything is running solid. Also its at 60k should i change the water pump now to save my opti from getting killed or should i just wait til this one goes?!1995 T/A (jet black) flowmasters, and a K&N with homemade ram air, descreened M.A.F. and T.B. by pass.......
Thanks DJ Taso...I try to keep it with the "stock appearing" lookOriginally posted by DJ Taso
Hey Craig, like the sig. She's a beauty! That's exactly how my T/A looked like when she was stock - same rims and everything! In fact, I still got my old rims in my basement
I love the look of your T/A also...first time I saw it, thought it was a '97 because it just looks so new and awesome.
Wouldn't be that bad of an idea. Cover your opti really well before unbolting the water pump.Originally posted by xxemoxx
