I am pondering getting a 4 inch cowl hood to compliment my new engine....but what good will it really do? is it all just cosmetic? apperently it creats a vacuum near the windshield and that draws more air into the air cleaner...is this true?
how much does a cowl hood really help?
A cowl induction hood can give you cooler air which is better air (as you probably know). You have to make it functional though by making it so that the vacuum is created from your air cleaner. You can fab some sheet metal around your air cleaner assembly so that the air cleaner is blocked from sucking in hot air from the engine and can only suck in cooler air from the cowl area. If you just put on a cowl hood, though, it will allow for cooler air to enter the engine compartment. I hope this helps, but I can't explain things very well.1991 Chevy Camaro RS (Is it plum or purple?)
Engine: 305 TBI (L03)
Trans: TH700R4
Mods: Some
CarDomain Site
Re: how much does a cowl hood really help?
Originally posted by seannz28
I am pondering getting a 4 inch cowl hood to compliment my new engine....but what good will it really do? is it all just cosmetic? apperently it creats a vacuum near the windshield and that draws more air into the air cleaner...is this true?Fred
