Im not sure what the deal is? i think there burned out.... Will one going out cause them both not to work?? i checked all the fusses no problems there.. But the light on the switch dosent light up either! they havent worked since i bought this car. Its a 99 LS1 Trans Am
fog lights wont work?
flyguy4484Tags: None
flyguy4484 -
My Z had a burned out foglight when I bought it but the other one worked just fine. Could be they are both out but since the switch dosen't light up it might be a bad wire, bad relay, or a bad switch even. Get a tester and have at it. Electrical probs can be a pain though......Good luck
flyguy4484
Ill check the switch first thing in the morning..... do these bulbs twist out?? its tight and once i get my hand in the way, i cant see???
flyguy4484
Ait , I think the incredible Hulk owned my car before me, i finally twisted them off with and open end wrench.... The swtich light started working once they where both out! im on my way for some new bulbs, maybe the blue ones the laws hate! thanks ...
Cool. Glad you got it working.......Now just don't go out and get all ricey on us with funky colored bulbs
BTW most of those blue tint bulbs use a blue filter to get that color which makes them dimmer than the clear white ones. If you want brighter try to find a higher wattage bulb.....Later
flyguy4484
well i put new bulbs in and still nothing! it must be the switch.... but my test light is broken, dam the luck
