Any one have any ideas on problems with gas guages on 99 camaros. The guage moves (sometimes) from full but usually stays there. Droping the tank sucks to change the sending unit so I would like to weed out any other issues 1st. THANKS!
Any Quick fixes to gas guage problems?
93 A4 Z-28: 383 all forged internals, CC306, Full Port & Pol. Heads 2.002 / 1.60, Comp-r Lift, Pro- Mag RR, 32# injectors, MDS 6AL, Adj. Fuel Reg., 160 Stat, Pcm-4-Less CPU, K&N CAI, 52mm TB, TB Bypass, 8.8 taylor wires, Shift kit, 3000 stall (built trans), ASM LT's, Meizer WP, 3:73's, Eibach Pro Springs, Poly-graphite Bushings, KYB shocks, BMR LCA / Pan hrd & relocation brackets, Budnik 17x9's., 1LE sways & ALM. Drive Shaft. And on and on and.....
Tags: None
