1. at the turn of the key with no cranking the engine the pressure jumps up to 40, then 3 seconds later, falls off to 20 lbs.
2. at cranking the engine at idle, pressure is running 32-35 lbs at idle.
93 Z28, LT1 w/ 24lbs/hr injectors.
bad pump? fpr? both? the fuel pump has a pressure baffle in it also right?
what kind of $$$ is a pump gonna cost.
any recommendations for a good pump for the street with bolt on mods?
Thanks!!!!
Thanks!!!!
