Ok, this is just a question, I'm not saying I'm going to do this or condoning the use of it, but I have been told tha there is a fuse you can pull on a fourth gen camaro, that will cut off the odometer and speedometer, but still allow use of the tach. Is this true, or is someone pulling my leg?
Odometer question
whitelightninTags: None
Yes it is absolutely true, but it also happens to be the fuse to most of the power accesories as well. But that could easily be corrected.
My guess is that GM engineered the fuse block that way to discourage people from doing this.
Just remember odometer fraud is taken very seriously.
whitelightnin
well, does anyone know which fuse it is? because my buddy tried it and has taken out a few fuses and now he cant get his odometer to working, we put them all back in, but dont know if it is burnt out or what, could something have been shorted out by trying this?
lol, dude you have to admit it does sound kinda suspicious that you ask this question SECOND instead of asking it firstOriginally posted by whitelightnin
now it just looks like you wanna find out which fuse it is and try it yourself
93 camaro Z28, A4 auto
http://www.cardomain.com/memberpage/503401
"he who hesitates is lost."
Sounds like a fishing expedition.
There is not a fuse that does specifically what you were asking.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Just disconnect the speed sensor on the trans. That should do what you want it to do. But if you are going to do what we think you might try to do, I hope you get caught.
Remember this...
-Lets say you save 10,000 miles on the odometer by doing this. That will make your car worth about $1,000 more when you sell it. That may sound like alot but....
-Now lets say you get caught. Everytime you bring your car to the inspection station, or anyother DMV place, they record your mileage. If there is ever a discrepency, your car will have a bad title. A car with a bad title is worth about half as much as a car with a good title.
To me, its not even worth the extra grand. But if you are just curious for your friend, like you say, then
of this applies to you.
No F-Body right now
Wont that screw up shifting if it is an auto?? and the cruise control will stop working too.Originally posted by Mark B
Just disconnect the speed sensor on the trans. That should do what you want it to do. But if you are going to do what we think you might try to do, I hope you get caught.Tracy
not only that...but I think you won't be able to get into Overdrive for automatics...I know my old 3.1 speedo stopped working and it didn't go into overdrive...it was a pain.
whitelightnin
Ok, thanks for the info, I know it sounds like BS, but after reading this my buddy, has decided to leave it all alone.Originally posted by Mark B
Remember this...
Our auto shift tables are %TPS vs. MPH, so you need the VSS for shifting.Originally posted by Mark B
It will definitly mess up the Cruise, but I think shifting is handled throught the engine RPM. Not the speed of the car. I had a speed sensor on my Ford Taurus go. The speedo/odometer stopped working but the car drove fine untill I got it fixed.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
I know several f-body owners who have pulled this fuse and it absolutely does not cause any conflict with the engine managment portion of the PCM. It is the fuse that the power mirrors are on.
Anyway, they would pull the fuse only half the time.....like pull the fuse going to work and put it back in when you are going home. That way they never had any discrepancies but racked up only half the miles.
Those guys were crazy, and I would never do this because I don't neccasarily agree with the ethics of it,
but to each his own I guess.
