I had my oil change done with that I had a set of Polyurethane Prothane Front and Rear Sway bar Bushings, as well as the Torque arm bushings. Took them like an hour to get the the torque arm bushing of, with grinding etc. The problem is the car now makes squeeking/rubbing noise whenever i brake or drive over imperfections. The back is not as bad as the front, is it a matter of time before they just wear in, or are they suppostue get lubbed?
replaced bushings, more problems
The Energy Suspension poly bushings I have installed came with tubs of a special white grease. Generous quantities of the grease needed to be slathered all over the bushings.... and it works... virtually every bushing in my car is polyurethane, and nothing squeaks.Fred
