good or bad (rpo codes)
  • good or bad (rpo codes)
    my car has he GU5 rear 3.23 ratio
    G80 axle, rear posi-traction
    G92 performance suspension package
    WS9 model conversion, Formula
    engine oil cooler
    t-tops
    GT raised spoiler
    de carbon shocks
    10 speaker audio system
    93 trans am, automatic transmission w/overdrive, all the options i think
    i m not sure ILE,IL3, ILB or 1LE. hope its 1LE
    whoat does this mean? how is the car?wich options on other f-bodyes are better, except ram air and WS6?
    93 t/a A4 3.23s
    99 Alfa Romeo 166 3.0 v6, red
    97 3.8 v6 A4 camaro, hardtop
    00 audi a6 4.2 40 valve v8
    Sounds good to me! Nearly identical to my Formula...nearly.
    KnightFire
    1993 Formula Firebird
    KnightFire's Lair
    Amsoil Dealer
      ha ha
      Knightfire, i know your formula is much better
      93 t/a A4 3.23s
        01. NGK TR-6 Spark Plugs gapped @ .035
        02. Accel 300+ Ignition System w/coil
        03. Taylor Spiro Pro 8.0mm Over the Valve Cover Wires
        04. 1995+ Vented Style Optispark
        05. Optima Red Top Battery (1050 Cranking Amps)
        ***FUEL DELIVERY***
        01. Aeromotive Adjustable Fuel Pressure Regulator
        02. LG MotorSports G2 Engine Compartment Fuel Pressure Gauge
        03. LT4 Fuel Rails
        04. 5/8" Re-inforced Feed and Return Fuel Lines
        05. Accel Flow Matched 44lb/hr Fuel Injectors
        06. WalBro 340lph In Tank Fuel Pump
        ***COMPUTER***
        01. Accel Digital Fuel Injection (DFI) Gen VII
        02. DFI to OEM Computer Harness
        03. www.PCMforLess.com Custom Chip (For Torque Converter Lock-Up)
        04. Hypertech G2 160 degree Thermostat
        05. Ecklers I.A.T. Sensor Relocation Kit (Relocated to Cold Air Unit)
        ***INDUCTION / EXHAUST***
        01. Moroso Cold Air Induction System
        02. SpinTech Custom 3.5" Exhaust
        03. Flow Tech Race Readies 3.5" Exhaust Cut-Out
        04. Polished & Port Matched 1995 Intake
        05. GM 1LE Intake Elbow
        06. Arizona Speed & Marine 58mm Polished Billet Throttle Body
        07. Hooker Super Competition 1 3/4" Long Tube Headers
        08. Custom 4" Kent Island Speed Y-Pipe
        09. Custom Ram Air Pan (Scoops Air From Under Car and Feeds The CAI)
        ***TRANSMISSION***
        01. Trans-Go Shift Kit (Stage III)
        02. Redline Dextron III D4 Transmission Fluid
        03. Summit Racing Transmission Cooler (24,000 GVW)
        04. B&M MegaShifter 4 Speed Ratchet Shifter w/Thumb Button (for the line loc)
        05. Energy Suspension PolyUrethane Transmission Mount
        06. Vigilante 9.5" 3,600RPM Lock Up Torque Converter
        07. Hughes Deep Transmission Pan w/Heat Fins
        (Holds 2 extra qts. of fluid)
        08. Rebuilt the 700R4 and put in a Art Carr Sun Shell
        ***SUSPENSION / DRIVETRAIN / CHASIS***
        01. Mac Sub-Frame Connectors
        02.Hotchkis 2 Point Strut Tower Brace
        03. HAL QA1 Front and Rear Drag Shocks w/Springs
        05. Steve Spohn Adjustable Pan Hard Rod
        06. Steve Spohn Extreme Duty Custom Driveshaft (Hand balanced)
        07. 13" dimpled GT Rotors & Police Pursuit Brake Pads
        08. Steve Spohn LCA's w/Relocation Brackets
        09. Moser 9" Rear End with 3.70 Gears and 35 Spline Axles
        10. Bogart Racing D-10 10x15"
        11. Bogart Racing D-10 4x15"
        12. Mickey Thompson Sportsman 26x7.50x15 (skinnies)
        13. Hoosier Quick Time Pro (QTP) Slicks 26x11.50x15
        14. SLP Driveshaft Safety Loop
        15. Energy Suspension Polyurethane Heavy Duty End Links (Front and Rear)
        16. BMR Tubular Light Weight K-Member
        17. Kent Island Speed Custom 6 pt Roll Cage with "Swing Out" Doors
        ***INTERIOR***
        01. Summit A-Pillar 2 1/16" Dual Gauge Pod Holder
        02. AutoMeter 2 1/16" Interior Fuel P.S.I. Gauge
        03. AutoMeter 2 1/16" Transmission Temperature Gauge
        04. MBA Custom Billet Aluminum Pedal Covers
        05. RK Sport Custom Embroidered Floor Mats
        06. Harlan Shift Light
        07. AutoMeter 2 5/8" Interior Nitrous Pressure Gauge
        ***APPEARENCE***
        01. K & N Billet Valve Breathers (2)
        02. Chrome Center Bolt Valve Covers
        03. SLP ZR1 17x9" Chrome Rims
        04. Reflective Concepts Custom "PONTIAC" lettering for rear bumper (red)
        05. Custom FORMULA windshield banner (In Red "Formula V8") Spt
        06. Custom painting on Air Dam "KNIGHTFIRE"
        07. Ram Air II Hood from USBody.com
        08. Custom painting on Fan Shroud Brace "KNIGHTFIRE"
        09. Custom Decal on rear tail light assembly "FORMULA" logo with bird
        10. Painted Calipers with 1200 deg Paint (Red)
        11. Polished Billet Aluminum Radiator Support Shroud
        12. Polished Billet Aluminum Throttle Cables Cover
        13. Polished Billet Aluminum Relay Box Cover
        14. Polished Billet Aluminum Door Sills
        ***VALVETRAIN/ENGINE***
        01. Mobil1 10W30 Synthetic Motor Oil
        02. SpeedPro Forged Pistons, Rings, Bearings, HV Oil Pump, ARP Rod Bolts
        03. Bore Block .030 over pistons, new cam bearings/freeze plugs
        04. Ported Intake to 58mm
        05. Removed the AIR/EGR Systems
        06. CSI Electric Water Pump
        07. GTP Stage 2 Heads (Competition valve job, 2.00/1.56 valves, fully ported and polished then flow bench tuned for 280/210cfm)
        08. GTP6 Cam 235/242 .568/.592 112LSA
        09. Cloyes Double Roller Timing Chain
        ***FORCED INDUCTION***
        01. TNT F1 "Wet Kit" 75-150RWHP
        02. NX Bottle Heater
        03. NX Fuel PSI Safety Switch
        04. TNT #4 Pro Purge Kit
        05. NX Switch Panel
        06. 10lb Black Powder Coated TNT Nitrous Oxide Bottle
        07. TNT Custom Ported 58mm Throttle Body "Wet" plate
        ***MISCELLANEOUS***
        01. Ligenfelter 2 Wheel Power Pulley w/belt
        02. BMR Throttle Body By-Pass Coolant Line Kit
        03. ARP Head Studs
        04. RK Sport steel braided brake line kits (front and rear)
        05. Redline Water Wetter
        06. Custom Line-Lock (Solenoid from JEGs)
        07. PIAA H4 Xenon Headlamps
        08. Simpson Cam-Lock 5 Point Harness
        ***STEREO UPGRADES***
        01. Pioneer DEH-P835R CD Deck Unit 40 watts x 4 channels
        02. Pioneer Passive 12 Band Equalizer
        03. Pioneer 350 Watt SubWoofer
        04. Rockford Fosgate Punch (250A2) 250 Watt Amplifier
        05. Orion 350 Watt Amplifier
        06. MB Quart "Q Series" Speakers (All The Way Around!!!, 10 In All).
        ***Spring 2004 WORK IN PROGRESS***
        01. Hotchkis Front 1 7/16" and Rear 1" Sway Bars
        02. Steve Spohn Fully Adjustable Torque Arm
        03. Aeromotive Complete Fuel System
        ***Needed Engine Dress-Up Items***
        01. MAP Sensor Billet Cover (High Polish)
        02. Dip Stick Handle (High Polish)
        03. Chrome Alternator
        04. Master Cylinder Cap and Cover (High Polish)
        05. Brake Fluid Reservoir Cap and Cover (High Polish)
        93 t/a A4 3.23s
          Nah...not what I meant...we have the same RPO codes except you have the T/A package...from what you put down...that was the only difference as far as RPO codes go...
          BTW...thats an old list of mods, LOL
          Go here to see whats new:
          http://www.angelfire.com/ga/cincity/index.html
          KnightFire
          KnightFire's Lair
          Amsoil Dealer
            those rpos were in your formula, now theyre gone
            i wish i had that on my trans am, heck i wish i could start the car
            i like the formula
            93 t/a A4 3.23s
              Re: good or bad (rpo codes)
              RPO codes are listen in alpha-numeric order. Look at the codes next to it to determine the first letter or number.
                whats the difference between 3.23 and 3.73 and other gears?
                what is the G92 performance suspension package?
                what is WS9 formula conversion?
                93 t/a A4 3.23s
