I saw a kid driving around town yesterday in a 93-97 style camaro. When i looked to the front fender (behind the wheel) i expected to see Z28, but it had F1 in its place. What is this car. Is it some company that puts a bodykit on the car- or is it some serious performance package?
F1 Camaro
It was an Aero package mostly,they also offered a CAI and floor mats and a few other things,it was offered at GM dealers as a GM option!!!!
Q: What's included in the F1-Camaro/Firebird-GT package?
A: This is a package available through most dealerships. It offers a variety of performance and cosmetic parts from the GM Performance Group. The following is a list of the parts for the F1-Camaro (and for the Firebird-GT) and can be ordered for your Z28 or Formula through your dealership:
Part No. Description
12363906 32mm front stab. bar, bushings, link kit, and track bar
12364002 17"x9"x50mm ZR-1 style wheels with P275/40ZR-17 Comp T/A tires
12363998 16"x8"x66mm ZR-1 style wheels with P245/50ZR-16 Comp T/A tires
12363902 6-speed Hurst shifter (leather wrapped shift knob)
12363925 cat-back performance exhaust (dual single-side outlet)
12363940 3 piece rear spoiler (primed)
12363915 4 piece ground effects package (primed)
12363978 cold air induction package (1993, for use with MAP)
12363979 cold air induction package (1994 and up, for use with MAF)
12363910 F1 Specialty Vehicle Package - everything above (1993)
12363911 F1 Specialty Vehicle Package - everything above (1994 and up)
123638xx coup floor mats (xx is 94-graphite, 95-gray, 96-beige, 97-neutral)
123638xx conv floor mats (xx is 98-graphite, 99-gray, 00-beige, 01-neutral)94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
that explaigns the f1 but my 84 was an F41?? anybody got an i dea what this ment?1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?
There are a couple books that explain the options for the various years of Camaros.... Camaro White Book, and Illustrated Buyers Guide - Camaro are two good references. I think both of them are out of print, but you can buy used copies on Amazon. I'll look at one of them when I get home and see if it has the details for the F41 option on the 84's.Fred
thanks i'm completely stumped i cant tell of any add-ons to a base z28 just has no emblems. at first i thought it was a formula1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?
If you can find the "build tag" .... glove box, console or end of the driver's door????.... you can go to 3rd Gen Org and enter the RPO codes and get them deciphered.
http://www.thirdgen.org/cgi-bin/rpo/indexFred
see my dad (was my dads car) tore those labels off thinking they wernt important1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?
1984 Camaro
RPO F41 (Sport Suspension) includes larger front stabilizer, rear stabilizer, and special front and rear shocks; available for sport coupes only. $49.00 This option was installed on 17,230 vehiclesFred
