abs/parking brake ?
  • abs/parking brake ?
    I got my car out for the first time this week and noticed after driving for a bit the abs/inop light came on. The parking brake lever does not engage like it used to either; it takes a few pulls to get it to work correctly; where it use to be just one pull. I did the back brake pads last winter but thought I got it back together correctly. BTW; the abs/inop turns back off when I restart the car but then comes back on when I drive for a bit. Is there anything obvious that I may have screwed up when doing the back pads?
    97' SS #497 1 of 50 White Hardtop M6,stock TB reworked to 52mm,SLP CC shorties, Random Tech DC Y-pipe, LT4KM, Taylor Spiro's and NGK's, BMR Adj Lcr's, TA, Boxed SFC's, Adj PHR, Floorpan brace w/ driveshaft loop, STB, GM 4:10'S, 1LE alum DS, Eibach 35mm front swaybar and Pro-Kit Springs, Bilstein HD's, Lou's speed stick with Hurst ball,LS1 front brakes, Earl's lines, Hawk Pads, BMR relocation brackets.
    Check the e-brake cable junction located above the torque arm near the rear of the trans. Both rear e-brake cables join at that junction and there can be no interferance. Also check that the rear calipers are well lubed, the parking brake is a seperate system from the hydraulics.....
      They have to somehow be related because when the abs/inop light comes on, if I pull over it takes 2 pulls for the parking brake to engage. If I turn the car off and then restart, the light doesn't come back on, until I drive it for awhile. It's weird because rear disc brakes don't have a star wheel like drum brakes. I'll have to take a closer look at it this weekend. Any other opinions would be greatly appreciated.
