If anyone has any ideas about what might be wrong please inlighten me. My 86 trans am 305 tpi runs like s@#$. When i floor it, the motor loses rpms and kinda sputters til I let off the gas. The it will run real rough, kinda like its runnin on 7 cylinders. I replaced the plugs, wires, cap and rotor, egr valve, I am at a loss, pullin my hair out trying to figure it out. I do have some vaccume lines that are in bad shape. Any help you can give is appriciated.
HELP MY TA
jarheadTATags: None
Is the check engine light on? If so, what codes?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
help my forum!!!!!!!!!
(typing in all caps is against the rules).
thanks.
jarheadTA
sorry about the caps.
No the check engine light is not on thats the thing, if it was i could get the codes and be able to fix it.
coil?Originally posted by jarheadTA
and..a bad vacum leak can cause serious stumbling.
jarheadTA
yea , i thought about replacing the coil with a super coil. I kinda want to know what the problem is though. How do i know which vaccume line in need. There are two hoses comming from the intake that are collapsed. But it doesn't make much difference if those line are plugged or open.
How about the hose to the fuel pressure regulator?96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Just because the SES light is not on, it doesn't mean there are no codes present. Some codes don't turn on the light. It might be worth it to check for any "stored" codes.
Are the vacuum lines connected at both ends? Have you checked them against the vacuum line/emissions sticker on the radiator support? What do you mean by "collapsed"?
Is it a speed-density or an MAF car?Fred
He said its a " 305 tpi".Fred
jarheadTA
The hose to the fuel pres reg is in pretty bad shape. What i mean by collapsed is, when the vaccum tries to go through the line, the hose is so weak that it collapses, same as if you just plugged the vaccum port.
