I had a ram air hood installed on my 97 T/A and had the whole car repainted while it was at the body shop.
When I picked it up, I pressed the unlock key on the remote and the one head light made this horrendeous noise which I think is the gear gone bad. I guess I have to order the brass gears.
Well it didn't have that when I brought it in but I can live with it that it might just went when it was in the shop. Once I got home I pressed the Lock button on the remote and the head lights flipped up and down and the horn sounded. Once again that terrible sound.
Since it didn't do the lights flipping up and down before when I pressed the remote I took out the manual and found a section on how to reprogram. Eventually I realized that I switched on the lights quickly, parking first, and then the head lights already came up, to see if it made the noise too.
Now instead of the parking lights flipping on and off when pressing the remote, the head lights do. Is it possible for them to have switched the wires to the lamps since they had most of them removed? It's pooring outside and I don't really want to uncover it right now.
Any words of wisdom?
Rene
Rene
You might be able to fix the headlight for free. The gears are loaded for 180º. The same side of the gear rises and lowers, ad nausium. Eventually the gear wears out, but the other half of the gear is still unused. It is possible to unbolt the actuator arm, manually rotate the gear 180º using the adjustor knob and reattach the actuator arm to start using the unused portion of the gear. Mine first went out 4 years ago and I did this quick fix and it worked fine until earlier this year. Now I have to do the brass gear. Not a bad fix for free.
