So i just bought my 95 trans am (LT1 and 4L60E) about a month ago, and it had a bad trans. So I'm upgrading and getting a completely rebuilt trans, and to save a couple bucks, im taking it out and installing it myself. I'm at the last leg of taking it out, all i have is one trans to engine bolt. There's 6 bolts, 3 on each side going up the housing that connect in to the engine. The bolt I am stuck on is the top bolt on the driver's side. I was screwin around with it for about 2 1/2 hours yesterday. I tilted my engine back and forth and tried gettin in from every angle you can think of. All I'm workin with is the usual hand tools, but i just couldn't seem to get it out no matter how hard i tried. Does anyone have any tips on what would be the best possible way to approach this without having to get too crazy cuz i hate not driving my car. Thanx everyone
Anyone have any tips?
black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to comeTags: None
The simple way to get those engine-trans bolts out is by removing the crossmember and allowing the driveline to drop down in back. Then, put all your extensions together to be about 3 ft long and go in and get it. Your wrench will be by the tail shaft and the extensions will go up to the bolt. Now you are free to move your wrench easily!
It's a piece of cake.Tracy
Hey thanx, I'll definitely give it a shot todayblack 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
yeah, i was definitely lying down on top of my engine yesterday with both arms shoved in the back trying to use an open end. I could manage to get it on, but i just couldn't get enough torque on the wrench to get it loose. If the other way doesnt work, thats what im gonna have to do again. Thanx for replyingblack 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
It'll work!! Have faith!Originally posted by Detroit_Bird
If that doesn't work, I've used an open end wrench, crawling over the top of the motor to access it from the engine bay. Slow, but it works too.
Make sure you use a 1/2" drive set or better. I had to use a breaker bar on mine. Man, were they tight! I would had never gotten them from above with an open end wrench.Tracy
Step 1: Install lift in driveway
.......the 3 foot extension and universal is the way to go.
Well, my Dad has a 4 foot extension and can beat up your Dad.Originally posted by N20LT4Bird
Your Dad only wishes he had a 4 foot extension!Originally posted by TraceZ
OUCH! I'm hit!! mayday mayday!!Originally posted by fastTA
