I just replaced the front brake pads on the WS6, is there a proper break in procedure for new pads, or can I just go out and use them as normal right away? They are OE replacement pads, nothing high performance. I replaced front pads only, rotors and everything in the rear are stock.
breaking in new brakes....
With OEM replacements or equivalents, it is ususually a good idea to not make any hard stops for the first few days. Other than that they should seat themselves properly.
Whenever I do brakes, I go out drive normal for 4-5 stops and then do 1-2 panic stops and call them seated. I have heard both sides of the debate on this though.....its kinda like the old "how do you break in an engine?" debate.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
