bare block, no cam, crank, rods or anything except main caps on.
how much does a bare LT1 block weigh?
Interesting article:The LS1 block is made of 319 aluminum heat-treated to the T5 standard by the Montupet Corporation of Ontario, Canada. It is cast using the semi-permanent mold technique which Juriga described as "....a cross between die-casting and sand-casting." The case weighs 107 lb. Compared to the Gen II's 160 lb. block, that’s a significant weight saving.
http://www.metalreviewcentre.com/ls1...ennium%20MotorFred
My a
LT1 block is in the garage. I will stick it on the scale tonight and post it's exact weight.
It wasn't easy but I managed to balance the block on my scale! It weighed in at 214 lbs with the main caps.
