Well took the car to the transmission shop and they did a road test, Visual diagnostic and hooked it up to a computer and did a diagnostic on the tranny and found nothing wrong. I do have a B&M shofter that is on the car but the wire had burned off and not connected anymore.But they think it might have messed up my computer on my car anyon have any ideas what I can do?They want me to take it to a dealer and have them hook my computer up and diagnose it. Any one have similar problems ?Refer to my post back a day or two ago for more info. Please help. This is for a Automatic 1996 z28 . Other message is below:
-I am writting due to a problem with my 96 z28. It is a automatic with like 93,000 miles on it. If I stomp on the gas and it gets to readline at like 5100 rpm-7000 range it starts to just roar and doesn't change gears. But If I let the car go through the gears at normal rpm range it is fine. What could the problem be and what am I looking at price wise to fix it? The fluid is also black color (Trans. Fluis) it is supposed to be a pink color. If I do a tranny service will that work ? Please help.
-Matt
dj_flavor@hotmail.com
Thanks,
Matt
-Matt
Thanks,
Matt
The remaining time in regular driving the trans shifts nice a smooth, yet positive. I've tried using the firmer shift option, but the 1-2 hits so hard that it is useless. The 2-3 shift hits hard and kind of makes the car a little unsettled, the 3-4 shift is equally hard. The end result is a less than enjoyable run. The car ETs a hair slower with increased firmness due to excessive tire spin. I suppose if I were running slicks or drag radials, I might see a gain by messing with the firmness.
13.410 @ 102.66 11/20/05]
