I cant seem to find a listing for the LT4 head gasket set at the local parts stores. I know the main difference between LT1 and LT4 is the intake gaskets. DOes anyone have a part number for the LT4 head set or more importantly the intake manifold gaskets? I dont need everything in the head set, so I might just buy the head gaskets and intake manifold gaskets individually.
help finding LT4 intake gaskets
Tags: None
i got mine from GM and they were like 22 bucks, right over the parts counter2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
I got em from scoggin dickey parts. Those guys are really knowledgeable and pleasant to deal with. Highly recommended!96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Hey Sean, make sure you get the 1236-7777 LT4 intake gaskets. There are 2 LT4 intake gaskets available and one of them has a restricted opening to reduce emissions. This was the one that cam standard on factory equipped LT4 cars. You don't want that gasket.
You want the 1236-7777. It has larger openings to allow maximum flow through modified LT4 intake/heads.
Thanks Kevin, I will call first thing in the morning to make sure!96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
