does anyone know about how much it costs to have larger valves installed into a set of heads or a reputable machine shop somewhere around savannah ga to get it done?
2.02 valves
fastTa -
We need to know if it is a LT1, LS1, Vortech, SBC, Brodix 15°, etc.
It is a little hard to help you wihout even knowing what type of cylinder head casting you are asking about. So I am going out on a limb here and assuming you are referring to the LT1 heads on your 93 T/A.
2.000" would be as large as you could go on the intake valve without significant machine work and moving the center of the valve over, and 1.600" would be as large as you could go on the exhaust side without doing the sameas above.
And really, unless you are looking to achieve more than 330cfm peak flow, you don't need bigger valves than 2.000"/1.600" on a LT1 casting.
