Yesterday my SES light came on - no symptoms indicating anything is wrong. So I went out and bought a scanner to diagnose the problem. Error code P0420 - "catalyst efficiency below threshold - bank 1". I have an appointment on Monday for it to be fixed - assume it is warranty work. I would love to fix it myself but don't know what else to do to narrow down the problem. I assume maybe it is one of the O2 sensors? Probably after the cat?
SES - P0420??
SES - P0420??
Dyno'd 5/1: 383.5 RWHP / 380.5 RWTQ (393 actual RWHP)Tags: None
You would have to watch the O2 on the scanner and see what its doing.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Could be the sensor, wiring, or the cat. To check, swap the after-cat O2 sensors side-to-side. If the problem stays on the driver's side, its a cat or a wiring problem, if the problem follows the sensor (code changes to P0430), its a sensor problem.Fred
Thanks guys - I am going to try what Injuneer suggested. I am just trying to learn to do my own stuff. I have always wanted to know how to tear into my own car - I really enjoy it but unfortunately do not know much. But you have to start somewhere right???Silver 02 WS-6, 6 speed, Corsa cat-back, SLP lid, K&N filter, BMR STB, !CAGs, Lou's short stick, MSD wires, MTI "Hammer" cam, ASP underdrive pulley, Hooker LTs, Hooker ORY, Comp 918s, TR pushrods, UMI Sfcs, UMI LCAs, NGK TR55s, Hotchkis springs
