keep the EGR or block it off????
  • keep the EGR or block it off????
    i am about to put headers on the Z and i am currious if i should keep the egr hooked up or eliminate it completely.
    any input?
    past rides:
    1994 Z28 A4 totaled
    Stock cam & programming - you might need it to keep from pinging at part throttle cruise & up hills at part throttle. They jack the timing up & lean it out for emissions & mileage and the EGR cools down the mix and prevents pre-ignition. If you stab a cam with more overlap & duration, then it might stay cool enough w/o the EGR. Otherwise, you might need less timing, more fuel, or higher octane.
      agree with Kevin 100%
        With the new Lt-4 hotcam, I plugged it off. No problems.
        The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
          Did LT4 cars have EGR valves? I didnt think they did.. The LT4 cam had enough overlap to run without it.
            The LT4 Corvette did not have an EGR system. Pretty sure the LT4 F-Body's kept the EGR valve.
            There is absolutley no "downside" to keeping the EGR system.... it does not hurt performance in any way. It can help with detonation when "lugging" the engine... as Kevin very accurately pointed out. You can also think of it as a selective "displacement reduction" system.... by displacing the air in the cylinder with a little "inert" exhaust, you don't have to add the fuel that would have been used by that air.
