Need Wiring Help!!
  • Need Wiring Help!!
    ok, I need to know which color wire the Acc., Run, and Start wires are on the column. I got the column apart and got a bunch of wires sittin there and don't really wanna go threw each one to find them. I'm lookin through All-Data, but they don't seam to list it.
    Thanks,
    Richard Harvey Jr.
    '94 T/A LT1 (stock) - SOLD
    Nevermind, I got it. Thanks to the info on www.the12volt.com
    1994 Pontiac Firebird Information
    Constant 12V+ -- Red -- Ignition Switch Harness
    Starter -- Yellow -- Ignition Switch Harness
    Ignition -- Pink -- Ignition Switch Harness
    Ignition 2 -- Brown -- Ignition Switch Harness
    Accessory -- Orange -- Ignition Switch Harness
    Tach -- White V6 Or White/Black (-) V8 -- At Coil or Distributor
    Neutral Safety Wire -- Orange/Black (-) -- Switch Base of Gear Shift
    Brake Switch -- Yellow -- Brake Switch
    Trunk Release -- Black -- Switch or Driver's Kick Panel
    Trunk Pin -- Gray (-) -- Behind left Rear Speaker
    Parking Lights -- Brown -- Driver's Kick Panel
    Head Lamp -- Yellow -- Light Switch
    Hood Pin -- n/a
    Door Trigger -- Gray/Black (-)OR White -- Driver's Kick or Light under Dash
    Door Lock -- Light Blue -- Driver's Kick Panel Reverse Polarity
    Door Unlock -- Dark Blue -- Passenger's Switch is Master Switch
    Horn Wire -- Black (-) -- Steering Column
    Windows Up -- LF=Blue, RF=Blue
    Windows Down -- LF=Brown, RF=Tan
    Cold Side of Brake -- Yellow -- Brake Switch
    VSS Lead -- Green/White -- Passenger's Dash White 32 Pin or Connector at PCM Position D-15
    Richard Harvey Jr.
      Well, that list is wrong. Still in search of the wire colors
      Richard Harvey Jr.
        I'll bet it is just like this.
          ohh, thanks, I needed that.
          Richard Harvey Jr.
