changing bulbs in the front turn signals
  • changing bulbs in the front turn signals
    changing bulbs in the front turn signals (99 firebird), looks to be a PITA.. I drove through wayyy too many storms on the way to and from Skyline and they now have water in them .. any easy ways to go about this?
    Re: changing bulbs in the front turn signals
    The bulbs have water in them? Do you mean the housings have water in them, not the bulbs?
    I've never seen an actual glass light bulb get water in it.
      Re: Re: changing bulbs in the front turn signals
      yah thats what i meant .. they have like a centimeter or two of water in them from the trip
        Re: Re: Re: changing bulbs in the front turn signals
        I know on a Camaro, there is a trim panel under the nose on each side that need to be removed, then the signal light housings are accessible from inside. The firebird is most likely similar.
        Anyone else have better details??
          Re: Re: Re: Re: changing bulbs in the front turn signals
          Yah I am probably going to be just going out and buying some jack stands and a jack and then removing all of that.. unless someone tells me different
            its true there is a panel underneath the front and then you have to reach up and get it from the inside which is a pain. i think it would be easier to drive up on ramps so you could get under and see it but its sure wierd to design a car where you have to go thru all that for a little light bulb!!
            Bruce
            01 Camaro
              yah it looks like a pita .. oh well I have to put it on jack stands to change the oil anyways .. itll be fun
                put the car on jackstands there ars small panels to remove then you shoulb be able to get to the light housings...I was able to replace mine from the top I turned the lights on and was able to see the housings with long arms it is still a pain and I have the scars to prove it but it can be done
                ya I answered elsewhere also
                1997 Trans AM WS6 vert
                1 of 463
                LT4 knock module
                strut tower brace
                SLP fan switch
                160* t/stat
                Pictures Here
                  I did the same on mine. Turned the light up, removed the cover around the light and reached down in there.
                  I doubt though it works on the newer ones (98+).
                    yah.. they made it rather difficult
                      easy!!!! 5 minutes to do.. having the headlights up DID let me reach in there and switch it right out. thanks guys
                        But why did they leak in the first place? Have you determined that and fixed it?
                        Dave S
                        2000 Black Camaro SS
                          My left one leaks and I cannot find where Just a Pontiac thing I guess
                          1 of 463
                          LT4 knock module
                          strut tower brace
                          SLP fan switch
                          160* t/stat
                          Pictures Here
                            We get a lot of big rain storms down here in South TX and my front drving light/blinker lenses would always fill up with water too. As soon as the hot glass of the light bulbs would touch the water, POP!
                            I got tired of replacing bulbs every month, so I just pulled the lenses out and drilled about 4 small 1/4" holes in the bottom of the lens and re-installed them. The small holes are completely hidden and I never had standing water in them again.
                              HMMMMMMMMMMMMM I did that on my old LeBaron Hadent thought about it for the bird thanks for reminding me
                              1 of 463
                              LT4 knock module
                              strut tower brace
                              SLP fan switch
                              160* t/stat
                              Pictures Here
