Hi all,
I have a 97 SS which has a high pitch squeek that eminates from the rear of the car when it passes over small bumps.
I think I've read previous discussions over the past few years of this being attributed to the rear spring rubber isolators or lack of. I thought all F-bodies had these isolators, maybe I should crawl under her and check.
It even seems like there was a technical service bulletin about this, but I can't remember.
Has anybody else had this problem and if so, what was the resolution? And if anybody could direct me to a service bulletin number if it exists, I would be most grateful.
Thank You,
Jeff Rumsey
Thank You,
Jeff Rumsey
Don't use spray oils if you want a nicely detailed undercarriage, it attracts and holds dirt like a magnet. The graphite works equally well and is less messy.
