Hey all,
New to the board, had a friend send me here. I have a 87 z28 that I have put a 93 LT1 into. I am using the painless wiring harness, and I'm having some problems.
Here is what happens: I start it up just fine, idles fine and drives fine.. then after about 1-2 miles of driving it acts like it's been flooded and dies on me. I am able to restart it, and it wants to keep dying if I give it gas. After I let it sit for awhile it will run ok untill I drive it around again.
We pluged the code tester into the computer output and this is what it gave us:
-EGR - DUTY 0% (all the time)
-CODE 26 QUAD DRIVER MODULE FAULT
-EVAP DUTY 0% (all the time)
-"SOLENIOD OFF (all the time)
-MAP(v) 1.35 at idle, decreases to .9-1.0 at rpms
-MAP("HG) 105-11 at idle, drops to 105-8 at constant rpms
-OIL TEMP -34 degrees F
Everything else was working right, when we did the check we were just sitting there and it didn't crap out at all, we even drove it around a little (not far). So it seems like if you only drive it a few blocks it's ok, but when you drive and it gets warm it acts like the car needs more gas then it actually does and starts running way to rich and kills it.. Any help would be great.
-wood
-wood
