please help
  • please help
    ok lets get right ot he meat. my turn signal for the front pssenger side wont work. the blinker just stays on like it has a burnt out bulb. but the other side work fine i do notice it a littel slow though. i checked the bubs, flashers (replaces witht eh hazards one. and i cat find any relay. please help this is really getting me upset
    1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?
    Are you absolutely sure the bulb is not burned out? Your post is not clear on this. Suggest replacing it anyway as you would have to take it out to check it anyhow and bulbs are cheap.
    R.i.K.
    '98 WS6 TA (white, of course!), Hurst Billet/Plus shifter, BBK intake manifold, McGard “blue-ring” lug nuts (12x1.5), PowerSlot brake rotors, Hawk brake pads, Stainless steel braided brake lines, Pontiac arrow, Hotchkis strut tower brace, MBA MAF ends, Reflective Concepts lettering, MTI carbon-fiber look airbox lid . . . and one greying, somewhat eccentric owner.
      replace the bulb, like roger said. but while you are at it..get some of that instant dry contact cleaner..from radio shack or whatever.. these sockets corrode like you wont believe..making poor contact.
      it one of both of these two.
        i'm confuzed!! i replaced the bulbs and flasher and it didnt work. but then i took the relay out and looked at it and put it back in and now it works????????
