well this sucks
  • well this sucks
    so I solved the mystery to my rocker stud problems and now after I did all of the valve lash adjustments and put the valve covers on and was about to do the intake and carb when I found this sheet lying on the garage floor that said:
    "These pushrods are not for use with guildplates. They are not heat treated and will wear through at the contact point"
    AHHH! so now I have to tear everything apart and start over with different pushrods cause I have guild plates and refuse to delete them!
    and whats worse is that I can't find HARDENED pushrods of stock length for a small block chevy, a family of the most common chevy engines ever, how strange is that?
    82 camaro x2:
    82 z28 w/ 305 (for now) 4 speed saginaw
    82 berrlinetta with 350 .060 over...3 speed auto
    The Z28 is back under the knife, after the transmission, now its the entire engine....will post pics when all finished.
