Hey guys, i while back I had a friend check my computer on the car for trouble codes. He has a laptop with the autotap program. It was ringin up the two O2 sensor codes behind the cats on both sides and then an air system code also. I dont know the numbers. I bought O2 sims and had my cats removed to take care of that problem. What is the air system code all about. A couple other problems are present also.......The car idles really rough. It will be idling fine and then start jerkin a lil, not throwin the tach off bad but it moves a little. It seems to do this more after the engine gets warmed up. I stop at a stop light and it just starts hesitating, like a misfire, but no codes are present to indicate a misfire. Also whenever i turn on my AC or Defrost it makes a clicking sound when idling when it kicks on. Also may be an oil leak in that area.
Thanks for any help.
Jason
BTW- I have a 97 T/A, Auto, 105,000, FLowmaster w/ removed cats.
Jason
The oil leak is most likely the front crankshaft seal. It is an easy repair, simply remove the belt, remove the damper, remove the hub. Pry out the old seal, drive in a new one. I will warn you that if the crank seal is leaking, most likely the other seals in the front cover are usually not far behind. There are two other seals in the front cover, the water pump drive shaft seal and the opti spark seal. The others require the removal of the water pump and optispark, as well as the air pump to get to them. They are the same type of seal, so with those kind of miles on them, they are probably close to leaking if not already. I had to do mine about 15K miles ago.
