I have been driving the T/A a more than usual this past week, manily highway around miles. Going to work this morning I noticed a whining noise coming from the rear. Are my rear-end gears going? If they are, what are a good set and ratio to get that works for a daily driver who is looking for a little extra power for my 95'T/A listed below? If the the noise isn't the gears then what the hell is it? Any ideas? Thanks in advance.
Rear-end noise?
with an auto, I wouldn't go over 3.73. Especially since you want it perfectly streetable. I've always thought 3.42 would've been a good auto ratio, but if you've already got 3.23's it's really aa waste, unless you're replacing the gears already because of breakage or something, which you are.Dave M
Ok, so thats most likely whats causing my noise? Thanks a bunch for the insight...
Originally posted by 02Z28if you're looking for a little extra low end bite, but still keep close to the same fuel [in]efficiency , then i would go with 3.73's....
if you don't really care about gas mileage and wanna really lose some traction, get 4.10's
Racr_X
Being a 95, it probably is the ring and pinion. If the noise is much more predominant either in just "gas on" or "gas off" mode, it's the ring and pinion.
The 97-99 cars had horrible axle bearings and if it's just a constant whirring noise that doesn't change gas on/gas off, it's the axle bearings.
Originally posted by Blevyou knowOk, so thats most likely whats causing my noise? Thanks a bunch for the insight...
does it only whine on acceleration?
does it only whine on de-celeration?
does it do it all the time?
only when coasting?
all speeds?
if it turns out to be the gears.. it will be while before they "go". replace them with gm gears though. most f body folks that tried to save moola and go with richmonds or whatever.. got a whinny rear out of it......... set up is critical too....
Wolfman, its mainly when I coast, but I still hear it accelerating, only not as bad.
Thanks to all of you for the pointers, really appreciate it. Great forum
Mine makes a constant noise at all speeds; an earlier post commented the wheel bearings were probably shot. I'm going with GM 4:10 Gears and all new bearings; can't wait to feel the difference!!
This is a great forum; has helped me many, many times.....97' SS #497 1 of 50 White Hardtop M6,stock TB reworked to 52mm,SLP CC shorties, Random Tech DC Y-pipe, LT4KM, Taylor Spiro's and NGK's, BMR Adj Lcr's, TA, Boxed SFC's, Adj PHR, Floorpan brace w/ driveshaft loop, STB, GM 4:10'S, 1LE alum DS, Eibach 35mm front swaybar and Pro-Kit Springs, Bilstein HD's, Lou's speed stick with Hurst ball,LS1 front brakes, Earl's lines, Hawk Pads, BMR relocation brackets.
Originally posted by Blevyou knowWolfman, its mainly when I coast, but I still hear it accelerating, only not as bad.
On another note, if you do get rear end work done (probably the case), I would replace the stock crush sleeve with something a little more sturdy.'95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
Originally posted by wolfman4:10's are no no for A4's........... they dont "git it"......
Red '02 Z28 M6 - purchased 6/24/04 with 11,706 miles
CAGS Eliminator
james562
can you elaborate on why to choose 3.73's over 4.10's in an A4. What are the results withs 4.10's anything bad
Originally posted by james562can you elaborate on why to choose 3.73's over 4.10's in an A4. What are the results withs 4.10's anything bad
The main reason is for streetability. If you put 4.10s in an A4, you would be keeping your rpms way to high, which would also result in terrible gas mileage.'95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
