Ive done some serious brunouts before and was wondering if this can cause seriosu problems on your car. Im sure its not good for it, but is it really bad? If so what can it do? My car is stock and i was wondering if the tranny problems im having are from the brake stands.
Brake Stands/Power BRakes
Does a shark piss in the ocean?Originally posted by lt14mlaIve done some serious brunouts before and was wondering if this can cause seriosu problems on your car. Im sure its not good for it, but is it really bad? If so what can it do? My car is stock and i was wondering if the tranny problems im having are from the brake stands.
Obviously, when doing this you're putting extra strain on drivetrain parts like the tranny and rear end. This will lead to premature failure. Besides, you shouldn't need to do a breakstand to do a good burnout, just stomp on the gas!
When I was young, stupid and didn't know any better I had a 2.8 V6 bird. I was showing off and revved it up nice and high in neutral, then dropped it into drive. It blew a hole in the muffler about the size of a potato, from the backpressure I assume. I was lucky that was the only thing that broke!Dave M
you guys ever put a drivetrain on a dyno with no airflow to cool it? It heats up pretty rapidly- long enough will boil the fluid. I personally destroyed an explorer diff about 6 months ago with only 250 ft-lbs dyno input for ~ 3 min. Think about what 350+ lb-ft will do to it with a much smaller ring gear.
