How do you post pictures on this? For the thread and my signiture?
pics?
For your signature you have to have a website to host the pic and then write it into your signature like this:
Write the website between these two:
[img] [/img]
For uploading pics you can just click on "manage attachments" on your reply screen and then upload the pics.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
embed the url address of the picture between the [img]........[/img ] codes. Do not include the space between g and ], I only did that so it wouldn't try to post it as a picture.
[img]http://cjcfo.fbody.com/members/injuneerzz@aol.com/PhotosD/FullView.jpg[/img ]
gets you this:
The "attach file" in the post isn't for makeing a picture appear in a thread. As N20LT4Bird says, "you have to have a website to host the pic" This is so you can link to the file from the post from the internet. The link is an internett address like "http://www." bla bla bla . You then put the link in the post as shown above and the picture will show up.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Appears you are trying to load it from your C: drive. You can only do that as an attachment. To "link" it and display it in the post, it has to be on an internet server.Fred
One thing I noticed too is that you should try to make a simple file name, short and no spaces.
I tried to post some pictures like "my trans am.jpg" and it didn't work.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
Originally posted by Black97One thing I noticed too is that you should try to make a simple file name, short and no spaces.
Either make it without spaces or changes the spaces into dashes or undescores.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
you can go to photobucket.com and make a free accout and host imgs there.. uploading them is easy.. and they even have a little box that will give you the link to the picture. Awsome site.
87 z28 w/93 LT1 and 700r4
Originally posted by Jeff 95 Z28I might be able to tell you why that didn't work. Spaces are represented by %20 (I think). If that file is still on that server, try my%20trans%20am.jpg
Just have the habit of putting a mile long description as the title of each picture for work.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
just testing my sig
Bruce, μολων λαβέ
