who to call for opti
  • who to call for opti
    i went to auto zone to check out the "new" "complete" optispark that they said theu had. it was just the guts and when i took the cover off it was not even new internals. they still had dirt and grim on the internal parts. so i walked of course but now i need a optispark for my 94 trans am gt and the local dealer want 695. i know there is someone on here that has them for 295.00 but i can not find the number any where. please help i am ready to drive my baby agian
    1994 Trans Am GT
    http://www.sounddomain.com/memberpage/208684/1
    Ram Air hood and airbox
    headers
    exhaust
    lowered 2"
    underdrive pully
    sloted rotors
    electric water pump
    air foil
    denso plugs
    taylor wires
    tinted windows
    eagle rims
    2000 watt stereo
    Call Jason Cromer at Sam Taylor. 1-877-726-8295
    Parts
    Check to see if yours is vented/non-vented. Probably non-vented
    1995 Firebird Formula
      94 is NON-vented.
      Also consider:
      Dal Slabaugh at Van DeVere Olds
      lockitup@bright.net
      800-362-9494
      He sometimes has better prices than Cromer.
        is 295 what i should expect to pay for it
        1994 Trans Am GT
        headers
        exhaust
        lowered 2"
        underdrive pully
        sloted rotors
        electric water pump
        air foil
        denso plugs
        taylor wires
        tinted windows
        eagle rims
        2000 watt stereo
          http://www.gmpartsdirect.com
          GM PART # 10457702
          CATEGORY: Ignition Distributor
          PACK QTY: 1 CORE CHARGE: $0.00
          GM LIST: $652.46
          OUR PRICE: $326.23
          The two people listed above will be a little cheaper.
            The link says: Non-Vented LT1 Opti Spark p/n 10457702 - $319.00, but it might be cheaper.
            I just got mine in yesterday, for my weekend project opti install #2.
              got it thru jason. should be here wed. it was 319.00 and i am not complaining it is a whole lot better then the 695 the dealer here wanted. he even went as far as sayiong it cost them moree then that. i said okay..so much for supporting your local dealer. oh well i am sure jason sells a million of them thanks to us. thanks for the help guys. oh the seals on the timing cover. is the instructions somewhere on replacing them. i bought the whole kit yesterday so i have them all. i also am putting on a electric water pump so will be plugging the waterpump shaft hole. i bought 2 freeze plugs that match the seals that came in the kit. one is a perferct match but the other is a little big. i am sure if i have learned anything in life that the one that is 1.25 inchs is the one for the water pump and i will be griding it all weekend long to make it work. as for the other are there any trick to getting them out or putting them back. and do i really need to do the one to the crank pully. there is no leaks but since i have it apart and have the part to do it i think i am going to. thanks
              1994 Trans Am GT
              headers
              exhaust
              lowered 2"
              underdrive pully
              sloted rotors
              electric water pump
              air foil
              denso plugs
              taylor wires
              tinted windows
              eagle rims
              2000 watt stereo
                Where did you get the kit? How much?
                  national parts depote. it was 12.00 and it came with everything even the waterpump gaskets
                  1994 Trans Am GT
                  headers
                  exhaust
                  lowered 2"
                  underdrive pully
                  sloted rotors
                  electric water pump
                  air foil
                  denso plugs
                  taylor wires
                  tinted windows
                  eagle rims
                  2000 watt stereo
                    painted water pum and timing cover
                    well car is apart timing chain will be here tommorow. opti the next day. got car all apart and clean and ready to go but bored. i end up ,asking off the timing cover and the water pum and painting them red. i know it will mostly be covered but it will add color and look clean. it sure is all new parts, under drive pulley, new ac delco opti and electric water pump
                    1994 Trans Am GT
                    headers
                    exhaust
                    lowered 2"
                    underdrive pully
                    sloted rotors
                    electric water pump
                    air foil
                    denso plugs
                    taylor wires
                    tinted windows
                    eagle rims
                    2000 watt stereo
                      GMpartsDirect.com (Flow Chevrolet in N.C.) site is good for getting an idea of parts pricing, and even a picture and description, but be carefull about the handling and shipping charges for EACH item you buy, they give you a low price for the part, and then make it up, and then some on S & H.
                      I use Dal, cause he is a good ole Ohio boy like me!
                      The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
